Would you be happy with this work?
Discussion in 'Electricians' Talk' started by Daniel_77p, May 9, 2019.
  1. unphased
    unphased Screwfix Select
    Then have the balls to take some and post. Maybe we can nit pick your work for a change.
    Coloumb likes this.
  2. dobbie
    dobbie Well-Known Member
    Will I forward you the bill for the camera.
  3. Dam0n
    Dam0n Active Member
    Not aimed at you at all unphased. Just simply stating that its not work that should be defended on any level.
  4. chippie244
    chippie244 Well-Known Member
    There's one on your phone.
  5. dobbie
    No there isn't.
  6. Coloumb
    Coloumb Well-Known Member
    Probably your phone is stuck in the stoned age.
  7. dobbie
    Sorry do not take drugs.
  8. chippie244
    Weird.
  9. Comlec
    Comlec Well-Known Member
    @dobbie has had a recent phone upgrade
    dobbie likes this.
  10. unphased
    Called your bluff, then, dobbie. You're all talk, no walk. Happy to **** off everyone else but can't back it up when asked to prove your own work is up to standard.
  11. dobbie
    I know my work is up to standard,i would not slate anyones work if it was fine.The photos of work shown by the original poster is abysmal as is the work you have posted that you have done.I do not need to prove myself.
    You also need to get your act together, stop giving out bad advice on this thread and on the oven thread where you have been proved wrong again.
    When you learn how to carry out workmanship to an acceptable then comment,if not carry on bodging.
  12. retiredsparks
    Very very sloppy.
    But the thing that concerns me is that full testing has NOT been done.
    IF it had been I doubt very much if the cowboy would have twisted the ring conductors back together again ?
    RS
    Sparkielev likes this.
  13. Pollowick
    Pollowick Well-Known Member
    That picture shows sloppy or bad workmansip in two ways. The first being that there are faults or problems - for example significant amount of conductor visible on the live connections. The second being that it is untidy and does not follow best practice.
    Criticism of the first area is fully acceptable, whereas for the second you need to ask, is it dangerous? is it a problem? It may not be, however, it could show his overall attitude and siuggest that he is sloppy in other unseen areas too so take it as a guide tio his approach.
    I know that my work can be untidy at times but at others can be pristine!
  14. Daniel_77p
    Daniel_77p New Member
    Just to update.... found this on closer inspection. Exposed core...
  15. dobbie
    Yes,I mentioned that in post 82 and 93.You need someone to sort this cowboys mess out.
  16. unphased
    Hi Daniel, I've seen your post on the other thread. That is dangerous, you need to get him back. Go through NAPIT as explained in the other thread. He will be told to correct his work.
