Would you use plastic pipe all the way with an easy fit bar shower kit?
Discussion in 'Plumbers' Talk' started by fizzy2, Nov 24, 2021 at 9:26 AM.
  1. fizzy2
    fizzy2 Member
    Hiya
    I'm just fitting a bar shower using the easy fit screw on brackets, instead of using the included offset reducer things.
    I've been plumbing in all the bathroom with plastic pipe and wondered if professional plumbers continue plastic pipe at the final connection, or switch back to copper at an elbow for the compression easy fit bracket of a bar shower please?
  2. quasar9
    quasar9 Screwfix Select
    From what I have seen, proper installers always terminate with copper.
  3. pppmacca43
    pppmacca43 Super Member
    I would use copper personally but tbh there is no reason why you cant use plastic, make sure you use the correct inserts(TSM Inserts if speedfit) and copper olives.
  4. fizzy2
    fizzy2 Member
    Many thanks - will use copper. Just picked up the item and the leaflet recommends copper also.
    pppmacca43 likes this.
