Sorry Mate to be a pain, but I need suggestions for a bathroom floor (Sorry, I'm in Weymouth, so can't employ you to do it.) The "Boss" says we need a new floor in the bathroom & in this instance, I must agree with her.The floor is boards, so would need sheeting with ply. I don't like tiles, as they are too slippery/cold, so what other options have I? All suggestions gratefully received. Thanks in advance, Malkie.
Evening, depends what she would like, i would go with a good vinyl of some description though. There are lots of cracking sheet vinyls, rhino, leolan, domo etc but if you would rather the "designer" luxury vinyl tile/strip floor i would suggest polyflor as the best option over karndene/amtico. Much better priced and top quality without the snob value of the other two. We do polyflor, mnt favourites (best value) would be camaro and beveline. http://www.polyflor.com/JH/news.nsf/DHP?Openform&Gallery=LOGOS&Image=11& http://www.polyflor.com/JH/news.nsf/DHP?Openform&Gallery=BORDERS&Image=1& Also, forget these kn ackers telling you it's a top specialist job to fit, it's a good diy project that anyone with a bit of patience, a sharp knife and the ability to measure accurately can produce a good job.
wots the polyflor strip flooring retailing at now audi. was up at polyflor's factory a while,making some nice stuff now.
We are doing the camaro for about £16m2 at the min. You can get the feature strips cheap and make a cracking design without the expense of the borders. If you do 2 srtips around the perimiter (straight) and do stepped corners instead of mitred, then a feature strip and fit the main body diagonal it looks mint. Takes a bit of time nut the effect is well worth it.
there are 2 different thicknesses, camaro is 2.5mm, expona 3mm, there are half a dozzen diffent ranges. The feature strips are just plastic strips 5mm, 10mm or 25mm wide, you fit them between the strips to build whatever design you like. About £25 for a pack of 50x5mm strips, £30 for the 15mm and £30 for the 25mm (but you only get 25 of the 25mm ones in a pack) If you do wood design and break every row with a 5mm strip it looks great..........takes ages though
