Zinsser BIN
Discussion in 'Painters' Talk' started by KDO, Oct 3, 2018.
  1. KDO
    KDO New Member
    Hi
    Can Zinsser BIN be brushed or rolled over a large area of bare wood for sealing knots or does each knot have to be ragged
    Thanks
  2. Astramax
    Astramax Well-Known Member
    Yes it can be brushed or rolled over a large area of bare wood if it's for interior application otherwise for exterior only spot priming is recommended.
  3. DIY womble
    DIY womble Active Member
    While your their astra will it sort out stain coming through a hardwall and skim from a removed chimney wall
  4. KIAB
    KIAB Well-Known Member
    Would have gave the wall two coats of SBR cement slurry to seal it before the hardwall.
  5. Astramax
    Sure will guv ;), would give it a couple of coats.
    DIY womble likes this.
  6. KDO
    KDO New Member
    Many Thanks I take it it’s good for knots ?
  7. Astramax
    Yes it's a shellac based product, Google Zinsser BIN and research the data sheets.
    KDO likes this.
  8. DIY womble
    Cheers kiab , not my wall , already done by a Russian builder , but said I'd ask for the customer, cheers astra
  9. CGN
    CGN Well-Known Member
    The spray can version is handy to have around.
  10. DIY womble
    Cheers ,didn't known that , I was bonding and skimming over an abandoned attempt by a builder and despite the extra layers warned the customer it best to use zin , thanks again to everyone on behalf of the customer, sorry to hijack post
    KIAB likes this.
  11. Astramax
    Always used Synthaproof myself to seal soot on removed chimney breasts prior to rendering.
