Hi Just Installed all my radiators in my house. Because of the size of my property i have decided it would have been better to have 3 seperate heating zones connected up to a system boiler and a high recovery pressure cylinder. How may zone valves would be needed as i have been advised a standard 3 port valve would be best . Many thanks for any advice/replies.
Consider something along the lines of; http://img.photobucket.com/albums/v395/thescruff/scruff-001.jpg more info on the size of the property how you want to zone what areas, etc You can fit as many zones as you like, for simplicity use a multi-chanel programer
Thanks doitall for the image and reply. So based on the picture I should go for 3 2 port zone valves for my heating system and 1 2 port zone valve for my DHW. Would you say this correct or do you recommend the use of 3 port valves as i have read these can be problematic. Thanks in advance.
with multiple zones 3port are not so good as 2port. as I said it depends on what you're trying to achieve. you will need the bye-pass valve though.
Just want to point out that a pressurised water cylinder MUST have its own 2 port zone valve wired through the cylinder over heat and thermostat. Also make sure that your boiler has a built in overhaet cut out switch as standard, required under regs for unvented hot water. Martin
Hi thanks to all for the advice. What would be a fair price for the installation of a system boiler and a high recovery cylinder. I have been quoted around a 1000 pounds excluding the electrical side of the installation. Any advice tips appreciated as always.
for simplicity use a multi-chanel programer I wouldn't do that. I'd use a programmable thermostat to control each zone. Each thermostat controls its corresponding 2-port valve and each valve has a switch that is wired in parallel with the other zones to switch the boiler on.
Have to agree on the prgarammable room stat for each zone,this is now the RECOMMENDED way to do it under part L1 etc. If you use wireless ones then you have more play in the positions use choose. You might at a later date want to move the stat 150mm sideways for a new piece of furniture of picture, far more difficult with a wired one. Also, think of all the wiring you save on. Martin
Agree stoday if you can find a sparkie that can wire them and get it to work. Any time we get complicated we have to do a line drawing for the electrician to follow. Thats why I said simplicity
Don't know where you got the price from but it ain't enough. Agreed, doitall, that price is way under.
Hi. Thanks for all the replies. With regards to the boiler and cylinder installation. The price Of 1000 pounds does not include the fitting of radiators or pipe work or any electrical wiring. Thanks for replies and tips regardless.
when you say multi-chanel programer do you mean 7 day programmer ??? sorry im not familer with the industry terms. Thanks in advance.
With regards to the boiler and cylinder installation. The price Of 1000 pounds does not include the fitting of radiators or pipe work or any electrical wiring. Shouldn't think it includes the boiler or cylinder either :O Multi-channel programmer if you look closly at the pic enables each zone to be progammed seperately, the two programmers in the pic are both 3 channels, or 6 zones
I would opt for the multi channel programmer. A heating zone in a large property may include several rooms. Programmable room stats have their place ,but not for controlling zones. They don't have a boost facility either .
Programmable thermostats don't need a boost because you can set different temperatures at different times, all as part of the programming. At the end of the day, you have to have a thermostat somewhere. You put it in the most typical room of the zone and balance the rads in other rooms of the same zone in the usual way.
