hi gents when testing a Zs reading today i got a >2000 ohm reading I was using the fluke 3 wire tester I put the neutral lead to earth and got a 0.2 reading indicating a neutral fault ??? yes ??? I then got a 250V reading between phase and neutral indicating the neutral is ok ??? yes ??? any views... All Mohm was >500 ohms R1 + R2 readings ok
hi gents when testing a Zs reading today i got a >2000 ohm reading I was using the fluke 3 wire tester I put the neutral lead to earth and got a 0.2 reading indicating a neutral fault ??? yes ??? I then got a 250V reading between phase and neutral indicating the neutral is ok ??? yes ??? any views... All Mohm was >500 ohms R1 + R2 readings ok oh dear should have used a megger :^O
hi gents when testing a Zs reading today i got a >2000 ohm reading I was using the fluke 3 wire tester I put the neutral lead to earth and got a 0.2 reading indicating a neutral fault ??? yes ??? I then got a 250V reading between phase and neutral indicating the neutral is ok ??? yes ??? any views... All Mohm was >500 ohms R1 + R2 readings ok Sounds like you not the tester Check the battery Check the leads on correct wholes and Fuses intact Check it is set to L-PE not L-N on loop test mode Join all leads together and zero (Fluke can zero lead on loop mode, unlike the megger) Try a Ze to confirm that the tester now works Re-test 'faulty' circuit if still FKD then fault find as usual. Yoda
Check the leads on correct wholes and Fuses intact Check the leads in correct holes and Fuses intact OOps Yoda
Just a little info. The meter only uses the neutral to light the display You can test Zs at a switch drop BTW by joining neutral and cpc together and hit TEST Might not be relevent to your inquiry OP but might be good for future ref. Si
Sounds like you not the tester Check the battery Check the leads on correct wholes and Fuses intact Check it is set to L-PE not L-N on loop test mode Join all leads together and zero (Fluke can zero lead on loop mode, unlike the megger) Try a Ze to confirm that the tester now works Re-test 'faulty' circuit if still FKD then fault find as usual. Yoda wot a good idea i never thought of that...........
wot a good idea i never thought of that........... If you know the answers, why post this in the first place. On this forum if you post a stupid question and make yourself look stupid, then expect a stupid answer. Yoda
