hi Guys, Just had the living room re skimmed at great expense, also spent a load on paint. But looking at the join between wall and ceiling, I have not done a great job of cutting in, any advice to rectify this? Many thanks!
A quailty brush, is the first thing you need,I use Purdy Monarch Elite & a steady hand. http://www.screwfix.com/p/purdy-monarch-elite-synthetic-paintbrush-2/79505 See this, same way here for many years.
What up there with Purdy for quailty paint brushes Astra. Got some synthetic ones here, unknown brand, free sample & they are like using stiff brush, no end of fabric softener will get them softer, using them for liquid dpm now.
Wooster synthetic brushes are also good. I've grown rather fond of sash cut brushes. Flowing, fairly fast continuous motion rather than sort, sharp bursts. Also, be sure to 'feather' the edge away from your cut line so that there's a gradient rather than a sharp ridge of paint at that edge. If you don't, when you roll up to that edge you'll still see the ridge and end up with a 'picture frame' effect which aint pretty
And cheaper than a Purdy, will get one tomorrow to try. http://www.screwfix.com/p/wooster-silver-tip-synthetic-bristle-paint-brush-2/8483g
What size brush are you using keane? Often peeps think a small 1" brush will be more accurate but it won't hold enough paint to give a smooth steady flow and you end up with a jagged line Would suggest between 2-3" brush. I've recently brought some new brushes and given Harris Synthetic (blue handles, BQ) a try with the slant cut bristles. Really like them for cutting in If you need to redo the wall/ceiling junction, then touch in ceiling first and slightly overlap onto wall - dont worry about trying to cut in both ceiling and wall Purdeys are highly recommended for sure but spending £20 on a brush won't instantly turn you into a pro ! Get up as high as you can to ceiling and get into a comfortable position, facing the wall your cutting in, i.e. Not working sideways to the wall Load up the brush and wipe off excesss, start cutting in a few mm lower than the line to get a 'feel' then work up to the correct line. Try and cut in with a smooth steady flow and you should be able to achieve 2-3 feet at a time (hence the brush holding more paint and good steady paint release) you get a feel for how much paint to load up, a new brush improves with usage and your cutting in line will grow longer with each single pass Difficult to put into words but definitely practice and trying different techniques helps, along with a decent (not necessarily the best) brush ! Good luck
Just ordered some new brushes & one of these to try, not normally a user of sash brushes, but going to give it a go. http://www.mypaintbrush.co.uk/buy-paint-brush/angled-cut-brushes/wooste-gold-edge-angle-sash-2
Surprised you haven't popped into the Decorators shops near you, plenty of stockists in the West Country The one feature of these brushes that make them stand out - how few bristles drop out. The big shame is that Purdys like a lot of US made products have a limited stock and range over here.
Surprised, I am inundated with offers (3 for 2, 30% off etc.) on paint from the big sheds at the moment and also the independents & builders merchants
I get loads of Screwfix vouchers, last ones I recycled (bin) and the next ones I'm going to trade with sospan for the paint offers!
Thanks Diydave great advice, and also thanks everyone else for taking the time to give advice! Purchased Harris brushes at B&Q, they are slant cut bristles, think it is 2 inches wide, I did try earlier and it looks better, but I think the damage was already fine with my first effort, I will start again by painting it white and then cutting again with my coloured paint. Thanks again all!
