What happens if the rcd malfunctions Mr C? - lets say a fault develops and the rcd is faulty..mcb trip time will then become highly relevant, and what kind of mcb trip time will occur in a no bonding situation?
Well up to 300ms before its classed as a failure, that 0.3 of a second, if the kettle casing is at 240 volts and the cold tap is at 0 volts thats full mains voltage through you until the RCD trips. If the water pipe is bonded then its 0 volts through you until it trips (assuming your not earthed anywhere else).
Well you will be ok, but its a good point about the outside tap, I've always said that an outside tap on a TNC-S system should have a plastic coupler on it.
