Hi We have an Aqualisa power shower Quartz Digital that has had the power supply removed for a few weeks. Then we re-conneted the power and turned the water valves back ON and nothing happens except all the lights flash on the shower bar and remote switch? No water flow or noise from the pump, both electric and water are there its just been off at the mains for a couple of weeks, Any idea's
Tried that and just tried feeding water in to system after the pum but still no joy, I'll keep trying thanks for your help
It is either something very simple....or the pump/processor has packed up. Give Aqualisa a call in the morning.
Press & hold the boost button down whilst someone else turns the power back on. Worked first time for us.
Remove power for over 10 secs, this should reset it. Failing that Hold down Boost button for over 5 secs then do the same with the On/Off button Shower should then come on. Bottom line is they are ****, your better off fitting this instead. http://www.bristan.com/epages/Brist...cts/"JU MTLSHX C"/SubProducts/"JU MTLSHX C^1"
