I was wondering if any one out there can give me some guidance on the following I need to create a concrete base for a hot tub Dimensions are Depth = 6" (15 cm) Length = 124" (315cm) Width = 92" (234cm) what would be the best way to do this - and what materials would I need
You will need approx 1.1M3 of concrete C30 grade, if you don't have a mixer, I would consider getting in a company that mix the amount you need off the back of a lorry and charge for the amount mixed. On a slab that size, I would fit a sheet of A142 mesh in the middle of the slab to stop it cracking.
Not if the soil is firm, I would put a plastic membrane down first, to stop damp coming up through the slab under the hot tub.
