Seen a large steam installation once. Nothing but ptfe used on joints from 1 inch right up to 3 inch . Apparently the boss white and hemp burns out at high temperature. Regards r2d2.
with gas, I would cut the thread a little tighter and use just jointing compound, as has been said hemp can not be used on gas.
You could just use gas compond but not a guaranteed joint, over a long run it could also fail with vibration and expansion. In this case I will be using welded flanges on the 3" and locktite string on the 2" down
Doital i hope you dont have to cut the threads by hand like i did as a lad, we had a set of Bridges adjustable dies, would not like dto do it now.
no; will be using a Rigid threading machine, done my share with the old hand dies lol not about to start again
hawkwhite is ok on (natural) gas by itself, like i say for domestic, not sure about big stuff 2" plus... LPG requires a different, but similar/thicker compound, such as calortex (think thats whats its called!)
