Astra I need your expertise, is Dulex Trade Diamond Brilliant white still the best for woodwork, I see they have changed their tins now. Had look around several decorator centres, one recommended Armstead Trade Quick Dry Gloss,which is waterbased, another suggested Sikkens Rubbol BL Satura, again water base satin finish. Any recommodations?
The latest one on the market is Crown FASTFLOW Quick Dry Gloss it has an incredible shine as good as an oil base if not better, worth checking out, you do need to use it with the fastflow primer undercoat although I would imagine any waterbase u/coat would be fine. Use more Dulux Diamond Satinwood these days as that's what I'm asked for.
Thanks Astra,intresting that Crown Fastflow, might try a litre for inside of cupboard doors, but I do prefer a satin finish on the woodwork, so I'll stick with the Dulux then.
