I'd like to learn how to make biscuit joints by practicing making some picture frames. I have a Dewalt DW631 and wondered if there is a bit suitable for using with that router. Is it just a case of setting the bit depth and plunging side on into the wood? Thanks, Joe
You could cut "biscuit" slots with a router by setting the depth and sliding the router into the timber. Whilst the thickness will be ok the length could be a little off - but won't be seen. however you could try cutting a spline joint or even sections of a spline joint. Or for drawers you could try a lock joint Your router is more than capable of doing these - If you google "slot cutting router bit" there are quite a few out there
Have a look on the Trend website: http://www.trend-uk.com/en/UK/product/342X1_4TC/4/113/biscuit_jointer_set.html for a set that works with te normal sized biscuits: 0, 10 & 20
You can get 4mm slotter cheaper elsewhere. The problem with biscuit joining a picture frame is that unless it is a very large frame the slot will show.
I'm not so fussed about them being on show, its just a little project with left over materials. I want to have some confidence in doing them, i plan on gutting and replacing my kitchen later this year! I've been looking at different joints for a while, the one sospan suggested seems stronger, being only the two pieces of wood, as opposed to a adding a biscuit
For Picture frames as your doing, you would really want to go with the Lock Joint, i used to do a fair bit of Framing years ago and that's how i done them. As always do a few test runs on scrap pieces to get an idea of what the finish will look like and make adjustments where needed before you go for the finished work. Goodluck with it whichever method you choose Bertie
Its an awesome bit of kit! i bought it second hand when a chippie i know well upgraded to a Dewalt 625EK. I did not know quite how useful these were before then, one of the most versatile bits of kit!
For Joining the lock joint, would you just use wood glue, or would a few brad nails make any advantage?
For finished framing, Eg Ash, Mahogany, walnut etc i simply used carpenters wood glue and tied them up with sash clamps until dry, since then other products are available which i would use now such as mitre adhesive or joiners mate, you can also use a pin gun if you so choose. Bertie
You just run the bit along the edge from one side to the other. With these it is best to use a small router table - you can either make your own or get one from the local German mini mart for about £20 when they are on offer. They aren't fantastic but they are very light and portable quite a few trade guys keep on in the van because of this. The lock joints are very strong Practising splined joints is well worth it as they make incredibly strong joints and can be hidden or a decorative feature and you can use the slotting bit
I've ordered a Trend lock joint bit. I have been playing with a trend worktop jig i treated myself to yesterday on some chipboard sheets most of the morning. The guide bush makes things so much easier! I might make a little router table - if i were to use some sheet MDF with a hole in the middle, clamped to a workbench, would it work? I was thinking about just using a FCU to switch it on and off. Moneys tight now (too much spending!) so i might hold off on a router table. Thanks for all the replies, you guys make me feel real welcomed!
No problem Router tables are very much a personal thing, so many people make their own and then keep on There are lots of plans on the internet and videos on you tube. One thing when using a router table and cutting end grain on small strips, use a sled or fence and avoid holding in it in our hands
Nothing wrong with making one from MDF use 18mm for it. If you dont have the money for a router table dont buy one mate, because you would need to justify the investment and how much use you would get from it on a daily basis. I would go with the MDF route for now, then build up towards a router table when you have the means. Quality tools are expensive and they take time to aquire, just view the home made router table as a stepping stone and practice.
