just bought a bosch hbn331e2b single electric fan oven ,total load rating (kw) is 2.35 there is no power wire to it can this be run with a wire and 13amp plug into socket or does this need to be hard wired with 6mm thanks
I'm not being off hand when I say this Biglad but read the manufacturers documentation that came with it. The manufacturer will specify the criteria for the electrical connection, in doing this you can't go wrong. Don't connect it in accordance with what someone else suggests, follow the manufacturers instructions. I'm assuming you've bought it new so there will be some documentation with it, if not, it's easy enough to find the instructions for it on line. Hope this helps.
There's your answer then Biglad! Seriously though, yes at 2.35 kW it can go on a 13 amp plug but should be on it's own radial circuit, not fed off the ring. Use 1.5mm H/R flex.
