Just a quick question: which way up for P4 chipboard? Green side/writing side up or doesn't it matter, and should I glue and/or screw? (It's for a loft conversion) Thanks WM
you will find when you come to actually lay the flooring that the flooring will go writing side down naturally, because you will start off with the "female" sides to the first corner. no need for glue, just screw down with 5x45mm screws after predrilling and countersinking. at each joint, mark the joist centre with a pencil line on the chipboard but do not screw down until after the adjoining board has been laid in position (this makes it easier to fit the boards if the tops of the joists are not all in the same plane)
You really should glue as well as screw (or use ring shank nails). PU glue is the best. For the ultimate you should also gripfill the boards to the joist - this helps to stop squeaks. Writing side is down - you should know this as some of the writing says "this side down"!!
belt and braces man, eh hallbeck ? personally, I think that if the boards are all nice and tight, and if they are well <u>screwed</u> down through predrilled clearing holes, then there is zero chance of squeaks developing, whether you glue or not. I hate ringshank nails in chipboard flooring btw ...
Is it not a reg that they are glued? I think NHBC require glueing together as well as glueing down - not sure though now i am thinking about it! Paslode nails do a top job of nailing them down
all edges must be glue as it does state this on some boards but it must be done on all. PVA is ok for this. I glue down on to the joists with pur glue then 63mm ringshanks from the gun or just glue if on jji beams if not the silent floor guarantee is invalid
Thanks to all - I think I'll play it safe and Gripfill, glue, nail and screw, I'll have covered all angles then! Should only take about 3 months and increase the weight by half a ton with all the ironmongery. Maybe screwing and glue the joints will do though. WM
you will find when you come to actually lay the flooring that the flooring will go writing side down naturally, because you will start off with the "female" sides to the first corner. It doesn't work like that. If you turn it over, you can still have the 'female' edges in the corner. Mr. Handyandy - really
don't use gripfill as its too thick. use a decent wood glue and you will find it will join together no problem.
> It doesn't work like that. If you turn it over, you can still have the 'female' edges in the corner. technically, you are right, but you would have to be some kind of ****** plonker to lay it upside down like that with a gap all the way along the wall/studs where the skirting would sit.
It doesn't work like that. If you turn it over, you [/b]can still have the 'female' edges in the corner. technically, you are right, but you would have to be some kind of ****** plonker to lay it upside down like that with a gap all the way along the wall/studs where the skirting would sit. No, the female bits will still be against the wall. Mr. Handyandy - really
It doesn't work like that. If you turn it over, you [/b]can still have the 'female' edges in the corner. technically, you are right, but you would have to be some kind of ****** plonker to lay it upside down like that with a gap all the way along the wall/studs where the skirting would sit. think of the gap when you have pulled it another 10mm out for expansion. Come on handy get your head in gear
Look. Think of it this way. murmac said the two female edges will be against the wall when you put the first piece in the corner(say long side against the right hand wall), Yes ? Now turn the board over and lay it long side against the wall in front of you(short side against the right hand wall) and the two female edges will STILL be against the walls, but the board will be upside down. Same as if you started in the left corner of the room, you would have to turn the board over. Mr. Handyandy - really
Ah! but, the groove 'the female side' is bigger on the top of the board, hence = technically, you are right, but you would have to be some kind of ****** plonker to lay it upside down like that with a gap all the way along the wall/studs where the skirting would sit.
Ah! but, the groove 'the female side' is bigger on the top of the board, hence = technically, you are right, but you would have to be some kind of ****** plonker to lay it upside down like that with a gap all the way along the wall/studs where the skirting would sit. What gap ?????? Mr. Handyandy - really
chip off the block think of the gap when you have pulled it another 10mm out for expansion. Come on handy get your head in gear If you install the board the wrong way down you'll inherit a bigger gap! won't ya. How FIK are your skirtings Handy?
Mr HA are you being serious ? if you set the boards back 10mm off the wall, (grooved side to the wall with the writing down) this allows a 15mm skirting to sit on top with no gap. if you turn the boards upside down (ie with the writing on top ) you will end up with something like a 30mm gap between the wall and the top surface of the board
chip off the block think of the gap when you have pulled it another 10mm out for expansion. Come on handy get your head in gear If you install the board the wrong way down you'll inherit a bigger gap! won't ya. How FIK are your skirtings Handy? Why ? Both ways will have female sides on both walls. Where's the gap bigger ? Mr. Handyandy - really
