I have always used something like 2X2 timber as floor bearers when constructing a new shed. If using either slabs or a concrete base, that of course brings the subject of damp to mind and the obvious way has always been either damp membrane in concrete or some kind of damp membrane between the slabs and the bearers, not ideal of course as easily bridged. What comes to mind, with all the modern materials about these days is using some kind of damp proof 2X2 bearers, i.e. some kind of material that is both impervious and unaffected by damp. The bearers being both supportive and the damp membrane as well. Anyone know of anything? Lengths of solid 2X2 plastic comes to mind but would no doubt be expensive even if you could get it. Is there anything on the market or is it a Dragons Den moment for someone (not me though ) Phil... PS sorry for quoting sizes in old money!
Buildings are still built with DPCs and DPMs so they are good options. Waterproof concrete used for basement construction is also a choice - maybe an overkill for a shed. The trick is to ensure the bearers are just short of the width of the shed so any driving rain coming off the sides of the shed will drip onto the ground. I like to screw EML (mesh) on the ends of the bearers to ensure adequate ventilation and to keep out leaves and rodents.
Best I can suggest is aluminium hollow section square bars. Can be screwed through floor into the hollow. Mr. HandyAndy - Really
You could use these as a base, no damp then. http://www.simplygardenbuildings.co.uk/ecobase-fastfit-shed-base-from-459-12542-p.asp Or these as bearers, not cheap mind. http://www.recycledplasticbuildingm...-without-point-100mm-x-100mm-hanit-ultra.html
50mm x 50mm x 3m @ £9:42p inc vat from below, other size as well. http://www.filcris.co.uk/products/product-details/cr50503pksbk http://www.filcris.co.uk/products/product-details/cr808012pstbk http://www.filcris.co.uk/products/boards-and-posts/square-posts Gave trade site link. Correct retail link here: http://www.kedel.co.uk/
Wow folks, many thanks for the replies, lots of options, really like the recycled plastic bit, seems to tick all the boxes I was looking for. Just need to work out the most economical source. Cheers Phil...
