Hi I need some advice on how to decorate a window board. I know the edges of the board need to be caulked. However the back bit of the board which stretches across the length of the window, should I be using a plastic mastic? I have never decorated a WB before, so was seeking clarification. In regards to the painting aspect, I have seen some good you tube videos that cover this. Any help would be great. Cheers IM
If it moves and may crack if filled stick quadrant along. Wood if painted or white plastic if you have upvc. It's cheep. If it's solid but has a joint showing along then caulk it. Allow you dry and paint, as that's what I normally do.
Cheers fella. I have upvc windows. What kind of white plastic should I be getting for the long edge pressed against the window?
local plastic centre will have 4.2m of bead for about £7. Just a little silicone to stick. When dry silicone again but the trick is using tiny amounts to fill in as you can't paint silicone. Some use wood and stick with no nails. Caulk and paint wood. I would just use decorators caulk unless bad. Never a fan of the quadrant but it dose work
