Recently I had a additional double wall socket put in the kitchen. The sparky had branched it from another doubk the wall socket which is directly behind in it in another room. The problem I have with this new socket is it takes ages from any appliances to charge. For example a standard iPhone would only charge a few % in like half hour where as soon a put in a diff wall socket it be fine. What could be the issue? Thanks
Just put the kettle on and thta was fine, did it in same amount time as it does in the other socket. What next
This isn't some sort of 'wireless' charging system, is it? Because, if it's a normal PSU with a cable plugging straight in to your iPhone, then there is something 'wrong' here. And - sorry - I think the most likely scenario is that you are not comparing 'like for like'. Ie - the battery was more flat this time. Or, the iPhone was switched on at the same time as charging. Or, the phone was receiving calls whilst plugged in. Or, the phone was connected to the interweb and running apps at the same time as charging. Or, the charging plug wasn't inserted fully into the phone. Or... you get the idea
I don't know too much about electrics, but I can only concur with everyone else....If you can boil a kettle in this socket, then you have a problem with your iPhone/charger
Just wondering if a reverse polarity would somehow give error output in the transformer for the charger? Kettle would still be ok! Mr. HandyAndy - Really
I've had trouble with my S3 Galaxay, since nearly 2 years I have owned it I have been through half a dozen chargers. There is an intermittent problem with the micro socket on the phone.
CEF are selling them, so I'm assuming they don't contravene any regs tbh, rather like a shaver socket doesn't.
Sen - i have yet to see one myself, but guess it has one built in for USB mate. Rulland - Cheers. I think they are popping up by the more well known manufacturers so guess they must be legit. At first i only noticed them from some dodgy looking thing on e-bay so did wonder!
They sell them here on SF. http://www.screwfix.com/p/lap-13a-2...-charger-port-brushed-steel-flat-plate/14309#
