Hello I have a tap used with a in line water filter. It is of this type http://www.freshwaterfilter.com/traditional-mini-tap-181-p.asp I have taken it apart and there is no washer. Just a valve with plastic that rotates 90 degrees to allow water to flow through it. Does anyone know how to repair this, I cannot see a way of taking it apart or is there somewhere I can get a replacement valve for this ? Thank you Chris
Looks like one of these but check the size. (Unusual, but no replacement part on their website !!) http://www.diy.com/nav/fix/plumbing...-9mm-Spline-Pack-of-2-11477997?skuId=11988704
