I'm looking to install a bathroom extractor fan at the weekend, and was just looking to get an idea of how long it might take. Going on the time it took the BT engineer to move a boiler (4 hours) and a builder mate and I to install a shaver socket (90 mins) I really can't see it taking longer than 2 or 3 hours: - bore hole in brick - install extractor fan - wire spur (either from kitchen if possible, or via light fitting) - test - do plasterboard repairs - bit of cleanup If anyone's done this before and thinks I'm being optimistic, please let me know! Many thanks
BT Engineer to move a boiler. How longs a piece of string, if no problems then yes 3 hours should be enough, but it could take all day if something happens unexpected.
boring the hole might take a while depending on your wall construction, drill and core bit. and how much energy you have!
Often with adding an additional socket / appliance, etc, the longest part of the job can be getting the cables from A-B (unless surface mounting) Do you have access from above from the lighting circuit Fan with overrun timer being fitted ?
How about fitting an in line fan through ceiling and out the soffit, far easier than coring a cavity wall
Weeeellll... the BG engineer bored through the wall in about 10 mins, so think it's pretty standard stuff with a diamond core drill. Getting to the lighting circuit will have to be holes in the plasterboard and a cable access kit I think, unless the spark thinks it's cool to take a spur from the kitchen (this is a downstairs bathroom, right next to the kitchen), literally through the stud, across 2 cabinets, and down behind the tiles (all accessible) where the boiler is, and where the electrics come in to service the boiler and washing machine.
You need a switched live from your bathroom light Dave and a permanent live/ neutral from somewhere if you want it to operate when you switch your light on.
Yeah, though it has a humidistat, so I'd like it to run independent of the light as this is the downstairs bathroom so it will be used all day by people not taking showers.
