Hi, Hoping someone can help advise. I need to change the internal doors in my house but am having extreme difficulty finding the right sized doors in any shop. The size required is 195cm x 76 cm (76" x 30"). The doors in B&Q, Wickes, etc are all 198cm, but say that the maximum trimmable is only around a total of 1.2cm at most. Can anyone suggest where I can buy a new cheap door of the required size, or recommend what I can do? Many thanks
You cut the bottom off the door to the size you want and then re-glue the internal frame back in again.
I had a similar problem with a semi-glazed door. Bought a solid wood one from Magnet & paid a real chippie to fit it...Well pleased.
