Hi, I am replacing pendant lights with tracks that fit flush to the ceiling, so the existing rose (with loop-in connections) needs replacing with something recessed. There's no access from above. Best bet so far could be a circular dry-lining box that can house a 4-way choc-block (such as http://www.screwfix.com/p/appleby-circular-dry-liner-box-35mm/90517), but I can't find a circular cover plate to finish the hole (the track is about 35mm wide). Any source of a suitable cover, or other ideas, please? Thanks in advance.
Fitted some lighting tracks in craft room here, just made a slot big enough for a click flow connector to fit through, about 45mm x 25mm size, simple job of filling hole. https://www.tlc-direct.co.uk/Produc...uct_partition_id=74643615667&test=finalurl_v2 Ashley J501 is another one, a bit larger though. https://www.tlc-direct.co.uk/Products/ASJ501.html
Overlapping box lid. https://www.tlc-direct.co.uk/Products/MTLIDslashL.html You will also need some 4mm screws.
That is not accessible when it is filled in the ceiling.The joint needs to be mantenance free or accessible.
Thanks, Deleted member 11267, I hadn't thought of googling for the word 'overlapping'! And thanks, KIAB - I like the plug/socket solution for ease of mounting the track. This looks like the way to go.
