My friend had a new gas supply fitted and the plumber notched the joice at the bottom. Is this legal. The notches are different depths. For example one is : joice depth 170mm notch depth 50mm and it's about 1 meter from the wall. Can someone tell me is it OK before he plaster boards the ceiling please. The plumber said told it's fine.
What about the ones that are 30mm deep or the ones closer to the wall. Do I need to replace my joices if you know
So is it your house or your friend's house? Any photos? Any notches in the bottom of joists are wrong, irrelevant of size and depth. Either sister a new joist side by side with the damaged one, or PU glue and screw 18mm ply both sides of the joist spanning a couple feet past the notches in both directions. Or bolt steel plate onto the joist both sides in place of the ply, again taking a few feet either direction.
If you run a gas pipe in a notch it must be protected by steel smack plates, obviously gas pipes in voids would be come into play
As always I stand to be corrected but I think that those are American/overseas documents/diagrams and not applicable to the UK
Notches should be no closer to a support than 0.07 times the span, nor further away than 0.25 times the span . Notches can be top or bottom, but not at the same end. Notches depth can be up to 0.125 of joist depth, where the notch is limited to the area of between 0.1 and 0.2 of the span, the notch depth can be increased to 0.15 of the joist depth. Those are the NICEIC guidelines, which I assume BC, have given them. Unless one goes totally ott with holes or notches, I've yet to be picked up on precise locations, note, this may vary between inspectors though.
Follow on from your op, So even in the 'Sweet area' of 0.1 to 0.2, the maximum depth of notch can only be 25mm in a 170mm joist, which would just accommodate a 22mm gas pipe.
Not according to this extract from the NICEIC guidelines - the drawing only shows notches at the top of a joist. Admittedly this is another organisation's take on their guidelines but why would they alter anything? https://www.voltimum.co.uk/articles/cutting-holes-and-notches-solid
Notching the bottom of a joist has always been prohibited since time began, so unless the goalposts have been shifted in the last couple years, to me it's still a big no no.
I haven't found a single document or publication relevant to the UK that permits notches in the bottom of joists whilst I have found many that state the opposite. Some, such as the one I posted earlier (#3) specifically state that they should only be in the top and that is from a local authority BC department. The most recent publication was the NHBC - January 2017 - so it would appear that I'm not dredging up obsolete documents. As I'm neither a registered electrician (no arguments about registration please) or gas engineer, please will someone with access to those organisation's guidance/regulations set the record straight?
From the NICEIC pocket guide, I will stand to be corrected, if required, but I follow the NICIEC/BC guidelines for holes in joists, as I'm an electrician, who was a scam member of the NICEIC until 2016. I have though, seen, loads of gas safe engineers notching the underside of joists to get a 22mm to the cooker location. Again, if the guide I'm using is wrong, and again, I'm not gas
Hi mate, the problem is with this country, is, more and more rules and regulations for anything and everything attempting to be implemented , apparently to reduce risks, there cannot, or should not, in my opinion be any other reasoning behind it. But, as we all know, there is, people make money out of it, so the more they hit us with, the more we can be caught out with, not rocket science is it?. We are told how to climb steps,safely, we are told where to run cables, reducing risk of damage etc, we are becoming a nanny state, where quite a % of our time is being spent on red tape and the 'B' word, I can't spell it, it's to early, if you can find another 'B' word that fits, is shorter; and contains a double L, then that can be quite satisfactorily be used instead, they are essentially the same Regards, Rich.
