I have a Grohe concealed cistern which has started belching, or whooping, for the use of descriptive words at the end of filling cycle. Its irritating and I need to resolve it Any advice greatly appreciated Chris
Sounds like a replacement fill valve could be in order. The sound it slight water hammer by the sound of it. Try reduce your water pressure first if you can it can help Replacement fill valves arnt expensive and are reasonably easy to fit, post a pic and I'm sure we can identify it and point you in the direction of a suitable replacement if needed
