Hi I am trying to apply a coat of high build masonry paint to the walls on my house which are rendered.Is it possible to get a smooth finish by troweling it on and then smoothing over with a float?I don`t really want a textured finish which I get with a roller,is there one that will give me a smoother finish?I have tried various densities of foam and lengths of pile. After I troweled it on I am finding it almost impossible to not leave any marks with the float and to get it on even.Any tips would be most welcome.
can i ask y u r using a high build paint y don t you use a weather shield or sandstone paint by far the easiest to get good coverage on the walls apply to coats by roller and hey presto your done
Not sure what you are trying to do here. A high build paint by it's nature is less easy to get smooth, it is likely to hold a texture (I am assuming this is an acrylic or emulsion paint you are using here, you've mentioned no brand names). There are a few finishing products that can be troweled but most have a lime content and are very specialised. Look to Oikos Bluebell and Lafarge Italia for advice regarding these. As Forest says you would perhaps be better looking at a high quality masonry paint like Sandtex Ultra Smooth or some of the other Akzo Nobel Masonry coatings. Cait
Yea I am using this because I have just had to put new wall ties in my house.The old ones had rusted away in places so I did them all.Where I removed the old there were fair sized holes to fill and I have found it impossible to match them up to the existing render when filling them.I didn`t want to rerender the whole house so looked at this as an alternative.I have tried covering where the holes were with dulux(textured and smooth)weathershield,but it`s still obvious where the holes were.I am using sandtex high build and it gives me ezactly the finish I want except for the lines left at the edges of the float.Any suggestions please?
Knowing more about what you are trying to do helps to understand your approach a lot more. The key to most successful touchups is to fill...only the area that has the hole and no more, to smooth...only the area that you filled and no more and to paint...only the area that was filled and no more...but given that you have already done the filling and tried the painting and that the holes are many and various, I have a funny feeling you will now never get a match. You could try using a damp soft bristled brush to dust back the edge but I suspect that you will end up with a sheen difference whatever you do. I would suspect that you will need to paint the whole wall again and even this might not "lose" the filling completely but would probably detract the eye from the problem areas. This is a tough one without seeing it. Sorry I can't be of more help. Cait
Thanks for your reply.It is a very tough one,I have tried just about everything to get a match,but couldn`t so decided the only way to sort it was to go over the whole lot with something thick enough that it wouldn`t show through.The high build gives me exactly the finish I want except for the marks left by the float,so annoying!!I do have a photo of one side of the house,can do some more tomorrow if they would help.This one probably not close up enough. http://photobucket.com/albums/b262/Stressed1/?action=view¤t=DSCN0601.jpg
HGC, Sorry, but I reckon you're never going to totally lose those patches without rendering the whole surface. OK, you've managed to get problem areas the right texture...which is smooth, but you have float marks right?? Are they actually marks or are they "texture" left by the float? If they are actual marks then I would say coat again, if it's texture...I don't know. What I'd do is get everything the texture that I want and then coat again giving a new texture - smooth or slightly textured all over whatever, just to get an even texture all over. Can I ask, are you determined to have an ultrasmooth finish??? or is it that you just want the texture to be the same all over? Do you just want these patches to disappear? I'm just trying to find out what it is you really want from all this. Cait
Paintycait, I thought about re-rendering,but the existing render is very solid!!Took an hour or so to do about a square meter with a 3kg makita sds,so I decided that was not an option.The finish I want is the same as I have on the extension to the house.This is just render,sponged to bring out the sand.I can get this finish with the high build,but use a float to get it.Where the float has been,it leaves marks from the edges as I move it along.I am finding it impossible to get rid of them because where I go over these it leaves more behind. I`m not determined to have an ultrasmooth finish,I just want to make sure I can`t get the finish I want.At the end of the day I can always use a roller and have a textured finish,it`s just that I would have prefered to get it the same as extension. Yes I do want the patches to disappear,when they are just painted it doesn`t look right on the house.Also there are quite a few cracks which I have filled just to make it even more awkward.
the 1 and only answer to this mate is to use a smooth roller your trying to do something a professional would do and they have a world of experience above you either get the pro to do it (and i reckon you already looked into that but found them to expensive)so now your trying to do a cheaper job w/o the experience mate your wasting your time your never get it rite and it will cost you loads added by a pro
this solution won't give you a smooth finish but you may be able to be creative and get close to the finish on your extension (failing that do your extension as well to match). However, you will cover your repairs without altering the architectural line of the render/building. You need; 2xbuckets, a big stick, building/soft sand, ordinary cement, PVA (wproof prefer), 1xsoft bristled banister brush. one bucket has cold water for clean up, the other is less than one quarter filled with cold water - add to it a dollop of pva and mix well - hand shovel into this equal parts sand/cement mixing all the time. You want a loosish slurry (wetter than paint). Dip in your brush and brush onto the surface, keep dipping and brushing on in m2's - make sure you keep the mix well stirred to stop the sand from separating and sinking to the bottom of the bucket. Lots of air bubbles on the wall means the mix is too thin, it's too thick if it clumps on the wall and won't brush out. Apply two coats, ideally leave overnight between coats. Don't play with the first coat when dry, it won't be fully set. Apply a nice thick second coat and style it as you go. You can have random stipples or swirling from the banister brush but in your case i reckon a (not too) damp sponge off will give you a good match. After a day of two you'll have a rock hard surface to paint onto (slightly thin the first coat). Practice on some plaster boards first to get your finish matched up. Tarpaulin the floor, don't mix up too much gear at once, use what you mix and keep your buckets clean at breaktimes. Faced with this option i reckon you'll accept a few tram lines in your high build paint!!!
Between Forest and David, I reckon you had some pretty good answers. The biggest problem is that if you hired one of us on consultancy to just come and see the job (up close in person) then maybe we could give you the answer but there is a level here of "what the heck is it he's trying to do?" and another of "what the heck does his extension look like?" and another of..."if I was standing in front of the job I'd know exactly how to solve the problem and if I didn't I'd know where to find out..." but given that this is over the internet... Yes it would be nice to have it the same as your extension but if it is the same colour as the extension and the texture is the same all over the area, I'd be happy with that given that it's a DIY job...so go with Dave's idea. I think the most telling thing was what Forest said about the fact that you are trying to do a pro job... It's the years, it's the standing in front of the job, it's the phoning your old boss or a mate who you respect in the trade...but more than anything it's the standing in front of the job with the years behind you.
DfP Yea I thought about doing this and tried it,obviously I didn`t get the mix quite right.Do I need to key the wall first,or will it stick ok on top of the paint that is already there.It`s not flaking or anything and is in fairly good condition. http://photobucket.com/albums/b262/Stressed1/?action=view¤t=DSCN0624.jpg http://photobucket.com/albums/b262/Stressed1/?action=view¤t=DSCN0625.jpg
Cait Yea I have had some great answers and am quite confident of getting a good finish now.The extension looks like this sort of finish http://photobucket.com/albums/b262/Stressed1/?action=view¤t=DSCN0623.jpg http://photobucket.com/albums/b262/Stressed1/?action=view¤t=264cc12d.jpg I have had a couple of people have a look,one wanted £9000 to use a high build type finish and the other wasn`t really interested.I do agree a pro would have the experience that I haven`t,but so long as I can get it looking reasonable I will be happy.I will keep at it though until I get it right. At the end of the day I can use a roller to get a finish which is perfectly acceptable,I would just prefer to try and get it to look similar to the extension(I will do that aswell so it`s the same). Thanks for all the replies
no need to key or seal that's the point of this. v. flaky surfaces need a scrape off as would areas of high relief i.e heavy textures. From your photos you look good to go straight on. Your mix looks pretty close to me, maybe a bit thin. I'm afraid the best description i can come up with is a consistancy close to melted chocolate. Although the process will take a bit of sweat it shouldn't be a hard action to perform. You can patch in the repair areas and feather off to some success. for a truly uniform look that hides the tie ins etc you have to do the entire wall. What part of the country are you in? David
Yea this sounds good,will try it.When I tried before I didn`t use any waterproofer in it,I do have some SBS so will use that.Sure I didn`t have the mix quite right.I`m quite confident now this will work and will do the whole wall.I`m in south Devon.
that's a shame only recently finished a run of work in the newton abbott area, if you were closer now i would've given you a couple of hours and shown you. Be persistent and you'll get the result. David
