I'm about to order a HITACHI C10FCE2 for home renovation and small projects. I've read it's a great tool and hope I'm making the right choice. I do have some questions which I mailed to ScrewFix a few days ago but I'm hoping to get a faster answer here. Questions: - Does it come with a UK plug? I live in Belgium which uses a different plug. - Is this the same device which was released 10 years ago or is a newer version? - Does this model have a laser?
I would look at a sliding mitre saw,would allow you to cut wider boards like laminate flooring. Pretty sure it doesn't have a laser, definitely no laser. As to blades look at the Freud LP40M 019 64 tooth 216mm blade, gives a lovely clean cut, can't be bettered.
