My first plan was to change the countertops in our old kitchen and I bought a router to make new cabinet doors for everyting, however... the old kitchen is seriously seriously dated and very well past its best and I will be changing floors/backsplash there as well at the same time so more or less everything will go, except the old kitchen cabinets which I just wanted to upcycle at first with new doors/worktops. The old kitchen cabinets are super old **** mdf very cheap units, Once I change the doors/worktops from outside it should look a whole lot better, but once you will open them they will still be the same probably 40year old **** mdf units So I'm a bit confused now, should I go all out and make completely new cabinets myself in more up-to-date style or upcycle the old crappy units with new doors/worktops? I have never made any kitchen cabinets myself in past, however have made lots of other stuff, tables/chairs/benches/shelvings and all kinds of other stuff so got the skill/tools to do it and from the few plans I have seen it doesn't looks that complicated- just time consuming, however not really sure about how much time this would take to complete exactly? Here are few pics of what I want to make - basically 2 large about 3metre long each base units and 1 set of hanging wall cabinets about 2m in length in total. everything would be made out of already planed pine boards I will get from local place+ plywood (so would just need to cut everything to length/size and fasten together+do a paint job) If you would attempt to make something like this how much time do you reckon it would take you from start to finish? Since I have never made cabinets before, it will probably take me 2x longer but that's ok
When I built my kitchen I bought the carcasses but made the worktops, the doors and the butchers block. I cannot see much advantage in making your own cabinets apart from an end of run special size.
You are talking about 'production'. ie getting as much done as efficiently as possible. Which would be easy if all the cabinets are the same dimensions. Not so with bespoke works. But effectively you have to create the equivalent components of a flat pack and then go about assembling it all as proper joinery. I expect a first timer who is reasonably competent could do all the making in about 2-3 weeks.
A lot depends on design, construction and materials. a simple cabinet made with pocket screw fixings is quite easy and could be made in a couple of hours. Changing it to use rebated joints adds more complexity and itme Similarly changing to an inframe design adds more difficulty but makes a stronger unit
B&Q / Tradepoint sells base units for £20, I couldn't even buy the materials and fixings for that price. However, wouldn't like to say how long they would last.
As above - very little advantage - if any at all - in making your own carcases. Kitchen units gain most of their integrity from being securely screwed to the walls and being perfectly levelled. If you do both of these things, they shouldn't fail. (Provided you don't get them wet...) Make sure they are 18mm thick cabinets, and jobbie jobbed. Then you can get on with the 'fun' bit...
There are firms around who sell kitchen ply carcasses, usually Baltic birch plywood, had a friend who bought bare units, he then fitted face frames & sprayed finished cabinets.
I've used these base units as gave a mate a hand to fit out his utility room at home. For the price, incredible value, yeah it's chipboard but we all know that Usual cam and dowel construction but once they're fixed securely to the wall, plus some extra stretcher plates,they will last, indefinitely ? It's any movement that will weaken them and of course, water will finish them off but that's to be expected As you say, timber (weetabix) alone would cost more, then uv got legs, fittings, etc on top
Good advice buying ready made cabinets. The other thing to consider is by going down the bespoke route is that you don't necessarily have to adhere to a modular type of construction. Depending on the style, size and available timber, you can build 'cabinets' around face frames and create longer runs in one go. As long as thought is put into the strength of the span, you'd save on materials too...mainly 18mm birch ply
Quite common in the states, building ply kitchen carcasses 8' or even 10' in length in one piece. You can even get 16' sheets of ply over there, but 5' x 10'x 3/4 is more popular.
I made all the carcasses for my bathroom because I wanted non-standard sizes, but wouldn't bother for a kitchen because standard units are so cheap. If I wanted cabinets where the doors are inset in the frame, I would work out my sizes and prob have the doors made up, but would make the frame myself. You can buy pre-made doors in any size suitable for painting yourself. e.g from ba components http://byba.co.uk/dealers/order-a-sample/ (you'll need to find a ba dealer - I use https://www.discountkitchenfactory.co.uk/ )
Doesn't worth the effort. You are prolly better off buying the new units and doors instead of making everything from the scratch, routing for profiles, sanding..painting, putting the hardware.
Ah the wife factor you have to factor that into kitchen design. Doesn't help when you have a wife that's 4 ft 11 and a kitchen with 10ft ceilings. Trying to get cupboards that she can reach but look right in the space meant nothing was a standard size. She even wanted the American fridge freezer out of sight so the unit was about 800mm deep in the end with doors that slide back into the housing. The doors are the fun bit, not only do I have to make some 2m curved butler pantry doors but the other doors so its gone from solid doors, glass doors, glass doors with mullions to now it is a solid panel at the bottom with a smaller mullioned window at the top. And she is trying to bump up the bathroom cabinets on my work list
I see it like this anything that is dangerous, life threatening or can harm your life; you require a licence for e.g. shotguns, cars, motorbikes and to get married ...... And to add into the mix I have two adult daughters that have long perfected the "Daaaaaaaaddd" way of starting a sentence
Yep that's the one, but the funny thing is the two sons ask the wife, then she drops the hint to me - but comes out somewhat different to what the boys asked for I do prefer the Daaaaaaaaddd, to the "I've been thinking / Wouldn't it be nice if ...." or the worst one "You haven't noticed...."
Oh wow! I never thought that the ready-made carcasses are THAT cheap, I always thought you are getting totally shafted when you buy kitchens hence decision to try to make everything myself, although those are mdf you don't see them much anyway once they are fitted with nice doors? What's the best place to buy these cabinets? I'm still not totally convinced about the mdf, maybe anyone has seen a place that sells some better quality (perhaps made from ply?) for not much more?
