Hi, need to price up to replace 3 hing doors with sliding pocket doors. I will need to remove stud work etc to fit doors. Bit lost on what to charge per door on this one as seems like a lot of work. Can anyone suggest what to price per door? Thanks
Why don't you break the job down into sections and cost from there? Remove door framing, skirting etc Take down wall as needed Re frame re plaster Hang door etc etc. It should not be that hard to work out a price Obviously you need to check there is nothing in the wall that will cause problems, pipes, cables etc
