Hello I am trying to replace an old tat alarm box with a new one. However I'm having a problem. The old connections where; Hold +, Hold -, Rtn, Trg, Stb. However the new connections are as follows; 0v, str, 12+, S-, tmpr, tmpf, flt, set+. I have connected the up as this Hold+ to 12+ Hold - to 0v Rtn to tmpr Trg to S- Stb to str And also liked 0v to tmpf as it says this in the instructions. However I can now set the alarm but the strobe light is always flashing. Please help. Many thanks Jamie
wow it is confusing, have u tried swapping the Stb wire to another connection? Cos this is ur strobe light wire. Does the manual tells u what those connection letters mean?
I haven't tried swapping the connection as I know it is the strobe. The instructions says STR- negative trigger terminal for the strobe light. Power for the strobe is derived from the Ni-MH battery. Note:- STR connection is not required in Serial mode.
Cos been googling around for wiring diagram and all referring to ur old connections but on a few has seem yellow/blue (although colour of wires make no different) r all connected to tamper.
I know what u mean. I'm going to ring technical support at weekend as they are only open till 5.30 and I dnt finish till late.
I fitted one of these to my alarm system when the old box (not tate) failed. Spent two nights up a ladder which was not helped by the previous persons attempt at messing around with the central control box in the house. Got a electrician out to look something else in the house at the time and he did not want the job of replacing the box. After two long nights up a ladder I realised why he did not fancy the job.
