Guys, Anyone have any experience in these units, looking to fit a 4.5kw to a hand basin, wondering if there hot water supply is any good? http://www.ebay.co.uk/itm/Small-Tan...630114?hash=item4b092f1e62:g:2-8AAOSwFV9XxI86 Cheers WOI
Fitted something similar in a hairdressers - ok for hand washing. I was lucky as I could use a redundant shower circuit to supply the thing.
I have not fitted that make, but others. Work OK for a handwash basin. Do check the power rating, most of them require a dedicated supply & do not work on a 13A plug!
The lower power the heater is, then the slower you will have to run the water, if you want it very hot. You have not said what the heater is going to be used for. Do reveal the whole story, Maybe someone has a smart idea...
It's for a small basin in a pantry, will hardly be used tbh, but thought, if these are any good and can be plugged in then I would add some hot water instead of just the cold.
For a small basin, maybe one of these 2.5kw so u could plug it in. https://www.tlc-direct.co.uk/Products/RRTAP1.html More to look at here https://www.tlc-direct.co.uk/Main_Index/Water_Heating_Index/Instantaneous_Water_Heaters_1/index.html For all of these, the water supply must be from the mains water supply, not a gravity-fed tank.
