Been taking out an old Miele kitchen, talk about made to last!!! I am now left with the hanger hooks in the wall, I have tried to unscrew them but they seem stuck solid, is there a trick to remove them or should they just unscrew from the wall?
Just basically a screw thread and a wall plug All of the above or pull em with a claw hammer Will blow out some of the plaster / wall but maybe not a problem if cupboards going back up or patch up Unscrewing them will be neatest Can't believe Kool not suggested his usual ...... he must be slacking somewhat In case you don't know ......... DYNAMITE ...... will remove those hooks (and other things in the surrounding areas)
Cheers will continue to try to unscrew and if all else fails I will try the dynamite I was going to pull the ceilings down anyway so the dynamite will help
You can get them in the claw of a hammer and rotate round to undo them if really tight, then finish off with a pair of pliers. Hate the things - hard to fit with a screwdriver and even harder to undo with a screwdriver.
They were screwed in, so will screw out. An adjustable spanner will slip on that cranked bit sideways - jobbie jobbed.
That's the problem Dev, they are rarely 'screwed in'. Usually put in by some cove using an adjustable spanner and all their weight.
