I would be grateful if you could if you could tell me where I might get replacement hinges for my Allmilmo kitchen door (fits over integrated freezer). I do not have the originals. The cut out in the door is 42mm diameter, 4mm from the edge. I am only able to find 35mm diameter. The carcase is 17mm. Alternatively, is there any way to adapt it to take 35mm hinges? I am in Edinburgh, UK. tel +44 131 6624528
SINCE THE HINGE HOLES WILL NOT BE VISIBLE ON AN INTEGRATED UNIT IT IS PRETTY EASY TO FIT ANY OLD B & Q HINGES.MOVE THE HOLE ABOUT 60 MM AWAY FROM THE EXISTING AND BE VERY CAREFUL USING THE HOLE CUTTER THO'COS ITS A REAL GIVEAWAY IF YOU HAVE 3 OR 4 35 MM HOLES SHOWING ON THE FRONT OF THE DOOR.
