load claculations for RSJ
Discussion in 'Engineers' Talk' started by sherb, Dec 12, 2006.
  1. sherb
    sherb New Member
    Can anyone tell me how to go about calculating the load on an RSJ beam so I can satisfy the building control guys. I have a 7x4 steel spanning a 2.2 opening. All that is sitting on it are floor joists, there is no wall above.
  2. mudhut
    mudhut New Member
    it really is very easy, sherb, but a little pricey. first, pick up a copy of the yellow pages. second, open checkbook wide. third, ring a firm of structural engineers....................
    on a serious note, calculating the loads, deflections etc yourself may be possible, but convincing bc will be another matter.
  3. grubber
    grubber New Member
    is there only 1 set of floor joists sitting on the beam. or is there going to be two seperate floors and joists sitting on the beam. what are the lenghts of the joists that are sitting on the beam. what is the rsj sitting on.i assume it is a single rsj sitting on 100mm wide wall. Brick or lightweight block?
  4. Part P Inspector
    Part P Inspector New Member
    Would it not be cost effective/safer just to install the heaviest duty RSJ for a given span and then your always covered, no?
  5. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    What do you want ? Three days we've been sleeping here, and you have to go and wake us all up!!!!!!!!!!!!!
    Only joking. ;)
    Two and a half days :)
    Mr. HandyAndy - really
  6. danbaile
    danbaile New Member
    I had a similar situation a few years ago. Being a Mechanical Engineer, I was familiar with all beam calculations. A book on dynamics will give you the necessary background. Watch out though. I used a reclaimed RSJ approx 10 x 5 by memory with no load above other than joists spanning 1.5m. The building inspector said that the beam was insufficient. I challenged him and asked to compare calculations consequently resulting a sameday pass. Have confidence in the figures and over egg your loads somewhat. I also proved that it would take a jumbo landing on my floor before the RSJ gave way!
  7. jimmythemap
    jimmythemap New Member
    Structural Engineer should cost about £200
  8. Charlie Far!ey
    Charlie Far!ey New Member
    Holy F*!
    You really dont know how to calc beams do you
    The 'engineer' states 'dynamics' - WTF is he on?
    Statics is for beam calcs - You need to know the loading of the beam is it a point loaded, UDL or two point?
    What its deflection max and the span.
    You need shear forces, Bending moments buckling moments .......... ofi - Get an s/e you have to have more money than brains for something this basic
  9. britishblue
    britishblue New Member
    Why reply now, to a question asked in December? Don't you lot read dates.
    BB
  10. daddyP
    daddyP New Member
    Well depends, im an engineer. if you can tell me the amount of floor from each side bearing onto beam i can send you some rough calcs or a program to use!!!
  11. daddyP
    daddyP New Member
    can you tell me the span of floor joists coming on from each side onto the rsj?? i can send you a rough calc.
  12. chippie244
    chippie244 Well-Known Member
    This was posted in Dec and OP hasn't been back since. I doubt he's going to reply.
  13. nick harrison
    nick harrison New Member
    Hi I have a w truss roof wanting to put 2 no rsj to cut out the w section it's 4.1 m wide and I'm going to brace the roof back off the steel also the floor is 4.8 m between the two steels I'm told to use 8x3 timbers due to the span but what size rsj is needed please
  14. Jitender
    Jitender Well-Known Member
    You need to contact a structural engineer, is it for a loft conversion?
  15. nick harrison
    I'm not going through building regs as don't have room for a rigid staircase so wouldn't pass building regs
    I have contacted a se and they tell me I need architect drawings to work off
    But trying to keep cost down as only for storage not a habitual room
  16. Jitender
    Other factors you need to consider such as a party wall agreement etc, if steels are to be placed on PW, could be a bit stressful if property is terraced etc with adjoining owners.
    Could look at telebeams but would cost about £6000. Need headroom of 2.1m from finished floor level.
  17. Jitender
    There are narrow stairs available with an alternate treads.
    [​IMG]
    May be best to speak to an architect to see if other ways round it.
  18. sospan
    sospan Well-Known Member
    So you want to lift into an attic space at least 2 potentially 5m RSJ's for a space that is going to be used for storage !
    Johnst1a likes this.
  19. Mr Rusty
    Mr Rusty Active Member
    With a trussed roof, the trusses don't just take the weight of the roof they also stop it spreading. In this case, I think you need proper input from a SE, otherwise you could run into problems in the future even if nothing actually happens. Any modification to a trussed roof is going to need some calcs and certs.
  20. Doall
    Doall Member
    I've just knocked through a side off a house into the garage and used concrete lintels. Opening was 1400mm and I used 1800mm lintels. B/c was happy with that
