I have the Titan TTB279SDS SDS rotary hammer still set which I bought from Screwfix some time ago. I may have lost one of the drill bits but I can't figure out which one. Comparing what I have to the list in the instructions available online it looks like I have everything but I have the space seen in the photo above in the moulded case. Is it possible this slot was always vacant in this model/set?
Not sure on model number but looks like I've got the exact same drill and supplied kit Just trying to finish my days worth of diy jobs around the house then I will take a look at mine Don't worry about chips comment, if the red wine has run low, he's often grumpy
No shortage but if he's had it a while and only just noticed then it's not a major problem is it. From the look of it only the chisels have ever been used.
I pretty much just use a 6mm bit nowadays, red plugs and thunderbolts although I did need a 300mm x 50mm auger to stick a scaff bar into a tree trunk recently.
I have the same item. When I got it, I contacted Screwfix customer support and the slot is left intentionally empty and no bit was ever supplied for it. If you check the instructions and paper sleeve all the items are accounted for.
I can see what the OP has done now, he has used the bit that normally sit in the slot he's highlighted and put it back into what is an empty slot on the left. DIY DAVE, yes your right it's a 6mm.
This Titan item is surprisingly good. I ended up getting one when I needed another to go with my Makita one. So far it has worked well with core bits, demolition work and quite a bit of drilling. I know its not gong to last as long as my Makita one but for £59 - £79 you live with that expectation.
I have a similar cheap SDS but if I lost a bit from it I wouldn't find a forum to go on to whinge about it. I would just buy another bit, Jeez.
Quite right. On a £59 set to have the all the accessories which actual so their job is a luxury and even on Screwfix a bit is £1.69 not worth the time to complain.
