Hi all I fitted a pair of mixer taps on the sink the hot tap runs ok with a wide flow but the cold tap runs like a power hose and splashes all over the place thanks in advance
Thats the design of the nozzle inside the taps not much you can do except if you have isolating valves under the sink you could reduce the pressuer there or fit a pressure reducing valve to the cold feed to the taps
