How good are 10.5 Kw showers? - my mothers existing 7.5Kw shower has packed and as she is getting the bathroom redone (bath out in favour of walk in shower tray) I was wondering if it would be better to move from electric to a thermostatic mixer. The flow from the old shower was never very good (although I don't think it has been working properly for a while). She has a 15 year old boiler on a open vented system and generally has a full tank of hot water. The cable etc. would need upgrading if she went electric versus the plumbing complications and need for a pump on the mixer. We have done the rounds of the local bathroom places and are getting conflicting advice so I was after some more opinions/thoughts. Thanks, Peter
Hi Peter. It's a bit subjective - what's 'good' for one person might not be good for others. But, a 10.5kW jobbie will certainly be noticeably better than the old 7.5kW unit - around 40% better flow? But an electric shower can only ever heat 'so' much water, so one 10.5kW make won't be noticeable different from another 10.5kW unit. Or, to put it another way, assuming your old 7.5kW shower was working as it should, then a NEW one of the same size wouldn't be any better in terms of flow. You need - as you know - to increase the power. So, electric showers are limited by their power rating. Newness will make no difference. (Tho' better designs of shower head might make they feel 'better'). I think it really comes down to what they want their shower for - how often it's used and whether a quick shower or an invigorating splooosh is what they want. A 10.5kW leccy shower will give them an adequate shower any time they want. I doubt they ever go "OOooooOOOhhh - that's goooood!" when having a shower, but it'll get them wet and warm and clean. Conversely, a shower mixer (and thermostatic is usually a sensible idea) can give you as good a shower as you want. But, that will come down to how suitable the plumbing is - does water GUSH out the bath taps when they're opened? How high up is the cold tank above the shower head height? Will a pump be required (usually costly)? (Although you can get neat shower units which have small pumps built-in to them - they are a very good compromise). Best advice, I guess, is to call in a couple of plumbers to survey the house and advise. Listen carefully to what they say (they may be biased...) and ask as many Qs as you can based on the above. Keep us posted
The most important thing you need to consider if your going to upgrade to a 10.5 Kw shower is what size cable is suppling the existing shower if its only 6mm you will also need to upgrade the cable to 10mm. How easy is it to do that without a major upheaval?
Could be complicated either way. For me going the electric route is probably best, plus your Mum will be familiar with their style of operation Upgrading the cable to 10mm could be straight forward, pull the old cable out, pull the new cable in at the same time. Worth checking your cold water flow rates with the shower spec, no point in going for a 10.5kw if a 9.5kw is enough for your flow rate. Spend the extra and get a thermostatic controlled electric shower. Make sure you have a 30mA RCD in your consumer unit, you'll need to upgrade the mcb as well probably.
Thanks to all of you for the advice, would definitely go with a thermostatic electric and I know the 6mm cable will need upgrading to 10mm. The consumer unit was changed 2 years ago and I spoke to the electrician at the time and he said he could go straight up (cu outside house in cupboard) the wall and across the loft if he could not pull the old cable through so would be getting him back to do that. I will definitely check the pressure and flow rate since the old shower frequently gave "low pressure" warnings and would shut off although I suspect this was as the unit was going faulty rather than actual low pressure. GiF - I think you are probably right about my mum being familiar with electric, I was showing her drench heads in the showroom and she was not impressed - said she did not like to get her hair wet! DA - good advice, thanks. My plan is to go over next week and take the old bath out. That way we can see how the pipes and joists run, she has her heart set on a low tray (25 to 45 mm high) and wants to avoid having a riser kit fitted. With the bath out of the way I can get some more ideas as to what's possible and if we get a plumber in it will be easier for him to see as well.
Cool. If the old shower gave 'low pressure' warnings, then - as GiF says - the mains pressure should be tested. If it's too low for a leccy shower (that's very low...) with no real prospect of having it sorted, then that would point the way to a thermostatic shower coming off your stored supply. However, I suspect your mains water supply is actually perfectly fine for a 10.5kW leccy shower, in which case what you say makes sense - your mum is used to this, and will even notice a distinct improvement. But - check it first. It's the simpler option, no question - it just needs that cable and stuff upgraded.
Thanks DA, yes I suspect the old shower was not working properly for a number of years - it is a remote Triton (20+ years old), located under the bath with just the temp and flow controls on the wall, heated water flows up a small plastic pipe. The flow from the taps seems powerful but for the sake of £15 I intend to put a pressure gauge on it once the bath is out. I agree - electric would be the simpler solution - I think I am letting my own wish for a really powerful shower overriding what she actually needs.
Have you looked at something like the Mira Event - the type that has it's own in built pump? Can be a good compromise especially if your mother has a cylinder of hot water. Just a thought.
Yup, these are good (and I - cough - did refer to shower units with wee built in pumps above... ) They work a treat, give a very decent shower (faaaar better than instant electric) and are simple to install. They also look pretty much identical to instant leccy showers and are as easy to operate, so 'mum' will find it a good replacement should you decide to go this way. If you always have loads of stored hot water and want a better shower than an I-E type, then it's a cracking option. Also you won't need to upgrade your wiring or necessarily even change it - just replace the MCB for a 5A jobbie (they usually use a transformer near the unit as they are very low voltage.)
I had not really considered a power shower but I will look into them. My experience with them has been that they are noisy because the pump is right there with you in the shower. It would presumably require new plumbing - cold water from the tank rather than the rising main and something like an Essex flange adding to the cylinder. But I will check them out as you say Electrician costs could be diverted to Plumber.
Rule of thumb method. If you FULLY turn on the cold wash hand basin tap then look for a visible reduction in the flow when you flush the WC. If you did notice a reduction? If you did, then you haven't got enough cold water mains pressure for a electric shower. Too many of these electric showers are fitted with insufficient water pressure and are be leagued with problems for ever more.
I've used them on occasions, and whilst they do 'whoooosh' inside, it isn't a noise that's intrusive. I'd imagine the Mira Event to be pretty good in this regard (I know my bro has one and loves it.) Yes, the water supplies would need to be balanced - so a cold water supply from the storage tank. A flange in your cylinder is a possibility, but I think in most case you'll get away without one - they don't suck that much water. How high above your hot cylinder is the CWS? And where is the shower in relation to this?
Thanks for the suggestions, I will be calling in these weekend to see her so will do a few checks and measurements.
