Hi can anyone tell me why my hot water is intermittent please I've got a baxi 105e it's had a new diverter valve and diaphragm and recently a new ntc thermister on the CH pipe , could it be the DHW thermister if so is this a drain down on my boiler to change Many thanks Graeme
Probably scale in the plate heat exchanger these can be removed and descaled or replaced tip for the future if you change one thermister change the other one at the same time.
Plate heat exchanger is a new one , thanks for that , is the thermister hard to change on the DHW valve Cheers again Graeme
Baxi 105, no turn isolate the cold supply remove the pressure (open hot tap), have a small towel by the thermister to mop any spillage remove cables, 13mm spanner and remove, replace with new reconect wires turn water back on. But from your symptoms doubt its the thermister.
Plate heat exchanger it is then mate , although i might start with the cheapest option first Thanks for your time cheers Graeme
Right update on the plate heat exchanger , that's ok so I'm stuck now , any other ideas ?? Cheers Graeme
You say The pate heat exchangers OK. Did you remove and inspect it? or did you remove and de scale it, how do you know its Ok?
Because I've had a plumber round , he's removed it cleaned it , took about an hour replaced it and it's still doing the same , he's gone away to have a think , I just thought I'd tell ya that's all , I'm just after opinions now tbh before I decide to get a new one , but I don't want to go down that road just yet Cheers Graeme
Intermittent Hot Water. I'd the same prob on a baxi 105 HE... Turned out to be a faulty Air Pressure Switch. £30 from keeptheheaton + 45 min DIY to fit.
Hi Graeme http://www.freeboilermanuals.com/pdf/baxi_disc/Combi-105HE.pdf Section 12.2 ~ Page 41 Hope it helps Ray
Hi, update on my DHW.when i turn the CH dial off my hot water is excellent , very hot constant as well ,but as soon as i turn the CH dial to where i normally have it for the heating my water problems come back , very strange Thanks Graeme
