Hi all, The first picture shows my current work in progress house. The plan is to replace the back door by extending the window, as per the second pic of a neighbour's house. [/URL] Does anyone have any knowledge on the construction of these 1970s houses? Would I need to brick up the hole left by the bottom of the door, or are the "walls" of these houses stud walls, covered by flashing/fascia? I presume the current window/door frame is offering no structural support to the building? Also, I'm a competent DIYer, but never fitted a window before; is there legislation for windows to be done by a professional these days with a certificate given?
Your house is identical to my sister's house, if built the same way it will be breeze block under the cladding.
