I need to make two cuts in a hard to access 22mm pipe and my normal cutter is way too big. I don't fancy spending £20 on a Monument or Rothenberger cutter just for those. SF have these at £2.99 each ... just wondering if anyone has tried them out? They look OK-ish and reviews are variable. http://www.screwfix.com/p/tube-cutter-3-28mm/49428 Or should I just use my Fein MultiMaster or a hack saw?
Used a multitool yesterday to cut pipe, not a clean cut and leaves the pipe with burr and cant push fitting on without filing around the edges but would have been difficult to get a cutter in.
I can deburr easily enough - inside and out. It will have end-feed solder fittings so being totally square and clean is not to much of an issue.
Will do the job. Once you have an indentation you'll be ok. Don't tighten down too much for each revolution as difficult to get leverage!
Use one of those regularly for the 8mm tube when installing a gas fire not worth the effort on 15mm though
Yes should be fine with the multi tool, tried a cut on an offcut. Just need to make sure it is squarish and debured on both in and out.
I had a similar situation where a multi-tool (Fein in my case) was my only option without creating a mountain of remedial work otherwise. It was one of those occasions where you justify the purchase of the tool on these grounds alone and wondered how you ever managed without one. The thing is I still come across situations where the multi-tool is the best solution and have even added a battery one to my Milwaukee kit bag just for where the job is quicker to do that than plug the Fein in. They have their limitations of course and if you cannot hold the work piece firmly it will just get vibrated to death without any other result. If I was asked what general purpose power tool to buy (other than a drill) I think this would be it.
Mentioned it to a friend last night - he rarely touches plumbing and he said "I've got one of those" and as he got it from the box he said "I have a set of these too", the round automatic ones including a 22mm. Both will fit, so I will try the pair and see how the little cheap one fares in comparison.
If the space is really confined. You can resort to a wire saw. Wire saws will cut through almost anything wood, metal, bone etc.
