My central heating is push fit plastic stuff. 22mm for the main circuit and 10mm for each radiator branch. I want a more stylish radiator / valve but the majority come in 15mm. I don't want to replace the pipe runs. Can I just use 15mm valve on the radiator and a 15-10mm reducer behind the wall thereby just replacing the immediate piping/valve?
all you need is a 15mm to 10mm reducer set ,this fits into the bottom of the valve ,and is a compression fitting. so you need one for each valve ,2 per radiator .
