Not being funny or owt, but it looks like those wings have never been fiited in the in situ box before..
I would truly like to thank everyone for their time and help I have done the first socket and can now do the others, can someone please tell me where I can buy more of these I need 4 more x
Can someone tell me what those things are called please so I can see if I can find them online, thanks
I've never seen them sold seperately. You buy the whole box, discard the body, and keep the wings. Each manufacturer has a slightly different shape, so there's no 3rd party aftermarket 'one wing fits all' solution.
Thanks! Yes i have been looking on google and can see they are different shapes/colours and sizes. If it comes to it I might have to buy ones that are similar and maybe glue them to the plastic box inside then screw the front panel on, gotta do something.
One alternative might be to get you electrician to disconnect the socket, totally remove the plastic box which will leave a deep hole. Glue, using a grab adhesive, a suitable thick piece of timber to the wall behind the boards, then when dry screw a 35mm metal back box into place. Finally, reconnect the socket and screw into place.
I expect they are called "those little red clips/wing/lug things" for cavity wall socket boxes. As they are so cheap to buy the whole box with the lugs then I think you would struggle to buy the lugs on there own. These are what I used from our hosts:- http://www.screwfix.com/c/electrical-lighting/back-boxes/cat7230011
