Hi Just had a new kitchen fitted - looks great. However the existing range cooker doesn't look quite right as the plinth doesn't exend across the front and it's legs loom out of place. I would like to exntend the plinth under the cooker (there's some plinth left over that would do the job) but the cooker legs seem to be 50mm dia (maybe 48mm?) and all the plinth clips I can find are 30mm. Any idea wher I can get 50/48 mm plinth clips? Thanks in advance. Stuart
Try using Terry clips Screwfix call 'em Tool clips part no 12963 are 1 1/2 " they should spring out big enough. Regards, teabreak PS Check the ventilation requirements for under the cooker with the makers first before you do it, there might be safety issues if the legs are meant to be open. Might be a fire risk for gas or electric and also lack of air flow to the burner if it's gas.
