Hello. I have built a small internal lobby leading to the bathroom from the kitchen. I will have two doors, one from the kitchen into the lobby, the other from the lobby to the bathroom. I have got the frames fixed in place and now need the hang the doors (a first for me!). Question: Is there a preferred position for the top and bottom hinges up the edge of the door? - it's a standard moulded door 1980 x 601 (mm). Looking around the other doors in the house, they seem to have the bottom hinge higher up the bottom edge than the upper one is from the top. Is there a standard distance from top and bottom for the hinges and can they be equally spaced? Thanks for any advice/comments. diymostthings
I'd usually do 15cm down from top and about 20 from the bottom. Bottom hynge takes more weight so it usually set higher in the door EDIT: did not see Deleted member 11267's post. Two answers better than one!
Bottom hinge doesn't take more weight. More stress is put on the top hinge. The bottom hinge is not being pulled. Mr. HandyAndy - Really
Could you develop, i was taught that the top hinge is pulled on (i.e taking the weight of the door diagonally from the point of fixing) and the bottom is taking the sheer force of the doors weight. Not being picky, looking for an explanation.
I only ever put three hinges on fire doors , front & back doors, or heavier internal doors. on these eggshell internal doors (typical in houses and sold by the million in B&Q and Wickes) I'd only ever put two hinges on.
Any weight in sheer is being felt by both hinges but the top hinge has the weight of the door in tension as well. If you are fitting a third hinge to stop the door warping then it goes in the middle but if it is because the door is very heavy it goes closer to the top.
Ah, I've got it now. Thanks chippie, i had always believed the bottom hinge took more weight, but even thinking about it, it makes no sense
This is all presuming the door is closed. To be honest most of it is bollix and I've seen chippies arguing about which way the hinge goes but if you are that close to the operational tolerance of the hinge, door or frame you need to start rethinking the design.
I don't do a lot of hinges, and when I HAVE to, I don't really enjoy it, I would like too, its a patience thing
