http://www.ironmongeryonline.com/silverline-cable-pulley-set Does anyone know how I'd fix this to my house wall? I presume it would have to hold it away from the wall a bit. It's to help with my washing line. Thank you!
Unknown but being Silverline it will probably fall to bits before you had time to hang anything on it. Why not go for something like this, at least you can pack it away when not in use. http://www.argos.co.uk/static/Produ...vc:t|adp:1o3&gclid=CPvB8f7p_swCFRBmGwodJ1MBvw
Use a rust proof sash pulley, much easier,I used a offcut of 50mm square box section, cut slot in it to take pulley. Before fixing pulley in section, drill two fixing holes in it & attach to wall, then fit pulley in slot & bolt it in place. Or you could fabricate some other mounting. https://www.reddiseals.com/product/rustproof-pulleys/?creative=42143607169&matchtype=&keyword=
Home now, had time to rummage, but old links are dead,trying to find another UK stockist for these. http://www.farmtek.com/farm/supplies/prod1;;92809238.html Could easily fabricate one with angle back to back & spacer to enable wheel to move freely.
