customer having trouble with the above getting no hot water heating fine, so i replaced the diaphragm in the diverter valve still no joy so i presumed it was debris in the vavle so replace the whole thing once again no joy, boiler sending all the heat round the heating circuit then locking out and repeating the process, i then proceeded to remove and clean valve drained some of the heting to assure no debris in there now stumped any ideas ? [Edited by: admin4]
The sensors can make boilers behave strangely on ravenheats.. If i am right two green ones. They regular go. Hope it helps. [Edited by: admin4]
Is the boiler sending full rate to the burner when hot water is in demand? can you hear the micro switch clicking when a demand is called? have you tested the resistance on the hot water sensor? only saying this cause i worked on one the other day with the same problem and just turned out to be a resister, prices parts on these boilers aswell. [Edited by: admin4]
Did you change for new microswitches when you changed valve?? Are microswitches being made?? If not just to test i click the microswitches and hold them in to see if it does get how water, only for testing purposes! Would of thought a full valve would of done the trick. Not a great situation to be in is it.
yes full rate is achieved. micro switch is making i replaced that also, i dont understand how the resistor could stop the heat going to the hot water when the diverter is opening if you like. boiler is about five years old, making me look a right tw*t this boiler mysterious.
Question is has it ever worked?? Has someone thrown a second hand boiler in. I would go to absolute basics, check if it is piped up correctly!! May sound daft but it happens!! Have u checked the new microswitches for making and in your case if they are closing!! seems like they are not breaking and not closing the ch off. Could be faulty diverter allowing it to pipe threw the ch when not on demand! We all get jobs like that, be sure to post back when you get to the bottom of it, interesting one.
Also one of the sensors could be stuck open, for the price of them i would certainly change them to rule them out. Not much else it can be after that!!
yeah used to work lol. i will clean up the old valve and give that a try to c if its a faulty new one and i will change both central heating and hot water sensors. i will report back when ive either sorted the problem or smashed the fooker off the wall. thanks for your replies.
Had similar problem on mine, and it was the CH sensor. I know it sounds silly, but when you follow the water flow and look at the position of the sensor, it becomes obvious. The amazing thing is that Ravenheat Technical don'tseem to know it. Martin
yeah i spoke to ravenheat technical may aswell have spoke to a brick wall that is what i expected. thanks for replys once again.
just thought i would finish the thread off. i once again bought a new new diverter valve and problem solved so was a faulty brand new diverter valve wat are the chances.
Never had one yet!! Nightmare especially with the labour of taking out and then putting back in.. Least your sorted.
