Hi guys could i ask how much it would cost to take out a radiator? Will it be a problem to take one out or is part of a system??
A radiator is part of a system, they are pretty straight forward to remove, but the best way to cost it if you can't/don't want to take it out yourself is to phone a local plumber and ask for an estimate, as he would like to see know what you propose,ie is it being removed permanantly or is it a temporary removal, if permanent does it require capping underfloor,are boards readily removable or is it a crawl under job, it shouldn't be to expensive,but phone and ask, as the rates vary around the country
> Hi guys could i ask how much it would cost to take out a radiator? Will it be a problem to take one out or is part of a system?? yeah it's part of the system drain-down + capping off = 2 hrs work = £250 = job done
drain-down + capping off = 2 hrs work = £250 = job done You wish. Drain down - not if I can help it!! £45 my price
is that plus or including vat you must be short of work do you want a job Inc VAT. Its only an hours work. Fair prices up north and I dont rip people off. Working all day every day. Thanks for the offer though
