after exhausting the bs7671 i can-not find any exact deph for the requirement for burying cables..522-06-03 is the only reference i have found...as with most of this book ..very vague in its description. unless i have missed a paragraph.
Cables to be installed in ducts or pipes in the ground are not required by BS 7671 to have armouring and/or a metal sheath, if the duct or pipe is sufficiently strong to resist likely mechanical damage. In case of doubt, a cable fulfilling the requirements of Regulation 522-06-03 should be provided. Protective conductors which are buried directly in the ground must comply with the requirements of Regulation 542-03-01. All buried cables must be marked by cable covers or a suitable marker tape, and buried conduits or ducts must also be suitably identified. A warning tape above the duct or conduit run would be suitable. Cables, conduits and ducts must be buried deep enough to avoid being damaged by any disturbance of the ground reasonably likely to occur. This could include gardening/horticultural works, excavating for any local buried service pipes etc. Generally, it is better to locate cables etc. clear of such possible works. A depth of burial of less than 500 mm is usually inadvisable as shallow laid cables may be inadvertently damaged by general gardening etc. Cables that cannot be buried at a reasonable depth should be specifically protected, e.g. by ducts encased in concrete, or installed along an alternative route. Before any excavation is undertaken for cable or other works HSE guidance booklet HSG47 "Avoiding danger from underground services" should be studied, as it provides valuable advice on safety aspects. It is important to be able to identify exactly where hidden services are located and accurate records, including drawings, should be made before trenches are backfilled. Cable routes should be located on drawings by dimensions from some fixed object that is not expected to change for a considerable time, (e.g. a building). Road and pathway features may be relatively easily changed. Scale drawings are of little value unless very detailed. Concrete route markers may be installed at changes of direction of cable routes and at regular intervals along routes.
NJUG Publication 7: http://www.njug.org.uk/pdfpublications/Utilities%20Guidelines%20on%20Positioning%20and%20Colour%20Coding%20of%20Apparatus.pdf 450mm cover under footpaths (and private land) 600mm cover under roads Also as stated in New Roads and Street Works Act 1991: Sections 79 and 80 - consultation paper.
The original question and your answer could be streets apart,as a Utilities in a footway was not mentioned.
Water Regulations Guide R4.15 says 450mm. Shows a nice diagram of all service depths and separation distances. Refers to NJUG6 which is, I think, obsolete. limestone cowboy refers to NJUG7 which is also obsolete, but his link does link to the current recommendations.
Page 213 table 4A1 BS 7671 (brown book ) Installation methoud 17/18/19 would be relevent If you look there it gives minimum dimensions for cables in trenches... SF
Find a gravedigger - offer him cash-in-hand. 6 feet should be deep enough. Cracking reply there BAS,I am still laughing now...........
