Can anyone provide an unbiased opinion about Rexon power tools ? I am looking at buying their scroll saw. as it is powered by a 200W motor compared to 90W for other manufacturers.
I am pretty sure Rexon manufacture tools to price for certain markets. I have owned one of their M2501 mitre saws for 3 years, got through 5 blades and still there no play in any of the parts - cuts very accurately. My brother purchased a skinny cheaper version from a supermarket and it is a sloppy load of c**p. They clearly can make excellent tools and not so excellent ones. I guess you will need to touch and feel before buying. I believe there are other companies that market products to different consumers.........now let me think - is it B & D or Dwal something or other?
i have owned a Rexon bench morticer for about 3 or 4 months now and have been more than happy. it looks and feels excellently built, and is very accurate too. i have also just bought a Rexon two speed bandsaw, but it will be tomorrow when i first use it, but so far, looks excellent too. i would buy rexon products again. cheers
I've got a Rexon 6-inch jointer, had no problems with it, seems to be pretty well built and works well.
Rexon UK was set up in 1995 & is wholely owned by Rexon Industrial Corp.Ltd based in Taiwan. http://www.rexon.co.uk/ They appear to be aimed at the better quality, more expensive side of the DIY market. Their prime sellers are B&Q, Screwfix, Focus-Do It All, Cromwell & larger independant woodworking stores.
Borrowed a Rexon sliding mitre saw the other week. Seemed very nice, smooth and durable. Time would tell. I notice that in my local B&Q, one or two of their power tools have been overstuck with the Rexon brand (?) notably their bench planer and dust extractor. Woody
I brought a rexon 2500a miter saw about 3 years ago and while using it today it just stoped. Checked all the usual things ie power, fuse etc so decided to take a look inside. Switch ok bushes ok so took the motor cover off and hey presto found the problem the secondary coil windings had over heated and 2/3 of the wires had snaped. I have tried looking for spares for this model but non are avaible. Have now got the uk rexon phone number 01709876611 and will give them a call after the bank holiday.I found this saw ok for the money but if you are doing some serious DIY/trade then for a few pounds more I would recommend buying a better quality saw it will outlast any rexon product.
Hi, I've owned and used a Rexon bandsaw over the last 3 years with no problems at all, I particularly like the above and below table guide arrangement.
do you have any problems sawing in a straight line. My machine BS2310A keeps going off line by itself on anything over 1/4" thick. I have adjusted tension to no avail. Am i setting guides incorrectly or using too small a blade 1/4" David
..as a general rule, a narrow blade is used for curved cuts - it will be difficult to maintain a straight cut in thick sections, especially if you're relying on a fence as your guide. Ideally you should be using the widest blade possible for straight cuts, together with a single contact point guide, rather than a fence. The single contact point should have a slight radius (or a bearing) and be positioned directly abeam the blade, at the distance you require for your cut. A pencil line on your stock will be your reference - keep a close eye on the cut as your stock rolls along the guide....you will need to make constant minor corrections to the course of the blade - as you see it deflect away from your pencil line, make a correction by rotating the stock around the contact point of the guide to keep the blade on track. WIth a bit of practice you will start to make corrections automatically and will end up with a good cut.
Wow Sparkyman - you really put this poster out of his misery. I'm sure he has been sat next to his PC for just 2 days short of 3 years waiting for your reply!
