Hi All I have not plastered for a while. Left the trowels in the shed, and they are covered in thick rust. What is the best option here please? They were cheap tools, so should they be thrown out in the bin, and go for the new tools? Or are there ways to rescue them by giving some treatment with the elbow grease? TIA
Dosen't matter if the tool is cheap, it should be still looked after. Use a fine steel wool with a light oil, using a thin engine oil here.You might need wet & dry, not too course to start with, then work with a finer grade, again with oil,on a flat surface to clean the face of the blades first.. I always wipe my trowels over with a oily rage or spray with WD40 if they are not being used for a while.
You might need to start with a coarser steel wool, & work up to a finer grade, depends how bad the rusting is.
I stick a wirebrush attachment onto the drill every few months, put it in a vice, then cable tie the trigger on. I clean all my tools this way (although they are rarely as rusty like yours), works a treat.Wipe with wd40, or similar, and a rag.
I think my trowels were wet when stored in the shed. I should have dried, and cover with oil or WD40, but I was too lazy, and forgot about them. Thank you for the rust removing and storage tips, I will try to clean, and reuse them. I was worrying about leaving rusty marks on the plaster when using these tools, or maybe the steel of the trowels might have been damaged, and they may crumble, but maybe it is not the case?
Start with a good scrub with fairy liquid and hot water. Look a lot better already. Mr. HandyAndy - Really
Wow scrub with Fairy liquid and hot water can kill the rusts off? Never knew or heard that before, but will give a go. Thanks.
It won't kill the rust off, it will clean them of the surface dusty rust, then you will see the real damage(if any) underneath. Mr. HandyAndy - Really
When I replied, I was joking Oil and wire wool sounds a lot more practical. Glad to know these cheap tools don't need to be binned just because they are rusty.
Why do you lot have to make things so difficult. Wash them off with soapy water first, you will have an idea what is left to do. Blimey. Mr. HandyAndy - Really
