CAN ANYONE GIVE ME ANY TIPS ON HOW TO SEAL THE CONSERVATORY ROOF TO HOUSE WALL OTHER THAN LEAD FLASHING. HOW DO YOU USE THE FLASHING ADHESIVE SOLD AT SCREWFIX. THANK YOU
dont even go down that line! get it done properly in lead, and chased in. as the other stuff will in the give u problems.
Must agree. The Screwfix stuff is nothing more than bitumem paint and a roll of thick tape. And when it rains will leave horrible brown stains down the glass ! It has it's uses but do it or get it done properly.
Hi Timssey, i'm no expert but we've just had a conservatory installed. The company used a plastic alternative to led, it's still 'chased' into the wall but sealed with silicone. it finishes the job much better than led and allegedly doesn't crack over the years. It still gives the same zigzag affect down the brick work. You should see it if you look around the modern housing estates.
